4 members (Wally / Montana, Chip O, 1955 1 Series, 1 invisible), 86 guests, and 0 robots.
Topics128,051
Posts1,055,764
#61690 06/12/2006 6:18 PM
I have a '51 Chev 3100, w/'58 235, Offy 2X1 intake with 2 Rochester carbs. I have had the things rebuilt by professionals and I have rebuilt them. I am continually doing this.
Questions: Is there a carb that will bolt on in place of the Rochesters? If so, what and where can I find them?
Thruwurkin
Kennewick, WA
Half Ton Will Travel
God bless America...One nation under God
#61691 06/12/2006 7:31 PM
Carburetion specialist
Carter, Stromberg, and Zenith all made carburetors which will work.
Jon.
The Carburetor Shop
#61692 06/12/2006 7:33 PM
Stovebolter "carbking" is the king of carbs. You'll find his business quickly with a google search for The Carburetor Shop.
Mike Barnes
1950 GMC 1-ton pickup
#61693 06/12/2006 7:45 PM
Holley model 1904 from '56 and up Internationals and early GMC V-6 will bolt up also, and the jets interchange with current Holley 4 bbls. You will have to fabricate the linkage as the throttle lever is on the wrong side.
Bill Burmeister
#61694 06/12/2006 8:38 PM
Bill is correct about the Holleys. I guess my prejudice is showing. These things are an absolute bear to modify, so I don't generally consider them at all.
However, they can be used where other units cannot if one has a hood clearance issue, as the Holleys are at least an inch shorter than the other units.
Jon.
The Carburetor Shop
#61695 06/12/2006 8:50 PM
We just made the linkage with longer arms to fit the carbs, rather than modifying the carbs. Still, a direct bolt on is always the best choice. I've just had bad experiences with Rochesters and Carters, the Holleys were available so I didn't mind doing the fabbing to make them work.
Bill Burmeister
#61696 06/12/2006 9:06 PM
Langdon's Stovebolt sells Carter-Webbers, progessive 2 barrells with electric chokes, and they work nicely for about $60 apiece. You've got to buy an adapter and linkage since I don't think the one that works with the leakchesters will work with the carter-webbers.
#61697 06/12/2006 10:30 PM
Thank you all for your fast replies. You folks have cost me a bundle. I just got off the phone with Langdon's Stovebolt.
I bought 2 Carter/Webers, 2 adapters, 2 air cleaners and a linkage kit. $355 including shipping. I won't get them till next Monday so I won't drive the '51 till after they are on...don't want to take a chance of burning it to the ground with the "Flushchesters".
Thanks again
Thruwurkin
Kennewick, WA
#61698 06/13/2006 12:22 AM
It isn't new to hear some of you complain about the "leaky" Rochesters. I'm using the one that originally came with my truck. As far as I know, It has never been rebuilt. I have cleaned it externally - once. My truck starts instantly, even after weeks or even months(during a project) of not being started at all. I get good gas mileage, good performance, and it doesn't leak. I can't help but to wonder why all these rochesters leak after they have been "rebuilt". Am I just lucky?
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#61699 06/13/2006 4:40 AM
I was lucky enough to find a NOS Rochester on ebay. I bolted it on and it runs fine no leaks fires right up in the morning. But....I have had bad luck with rebuilts. I have 4 Rochesters sitting in my junk parts bin. Once you open em up they are never the same.
#61700 06/13/2006 5:43 AM
I recently rebuilt my Rochester B , it had the classic warped air horn issue and was full of crud. I was ready to junk it when realized how bad it’s condition was , but having nothing to lose I bought a 12 .00 rebuilt kit and used the replacement air horn gasket as a template to make one out of fuel grade rubberized cork material , the thicker gasket sealed up the air horn leak and the truck runs great . if you search carbkings posts he has instructions for reshaping the air horn and float bowl , however I perceived that marital happiness was at risk if I where to use the oven for carburetor improvements. grin
Brice
#61701 06/13/2006 5:48 AM
I hope I am just as lucky with the 2 I will be using soon. They are also NOS. I'll be putting them on a an Edelbrock. Still riding the fence between split manifold or fentons.
My Webshot Photos]
#61702 06/16/2006 2:39 AM
Quote
What prompted this question? Last Thrusday morning I started the '51 and heard a small "pop" somewhere, shut it down and started it again. This time no pop.
On Friday morning I started it and got a big "POP" and the truck was running rough. I checked the tailpipes and one was smoking black..real bad. I tried to adjust the carb for the rear three cyls...it would not adjust and had fuel pouring out of it when the engine was above idle.
I ordered the Carter/Weber set up from Langdon.
Today I checked the oil and found that it was about 1/8" above full and smelled like fuel. When I pulled the Horrorchesters off there was about an 1/16" of fuel laying in the bottom of the intake manifold.
I'm trying to get the truck ready for a cruise on the 23rd. Sure hope the new carbs get here soon.
Thruwurkin
Kennewick, WA
#61703 06/18/2006 4:11 AM
U
Junior Member
Junior Member
U Offline
I have a 69 C-10 with a 250... Will the same replacements for the Rochester work on mine as well??
thanks!
- Joe
Stupid like a fox.
#61704 06/18/2006 5:02 AM
Quote
thanks!
- Joe
I can't answer that. If you call Langdon's Stovebolt @ (586)739-9601, he will take the time to discuss what he has that will work for you.
Please let us know what you find out.
Thruwurkin
Kennewick, WA
#61705 06/24/2006 2:38 PM
I finally got the Weber Carbs from Langdon Stovebolt hooked up and operating. I took the '51 down and had the carbs balanced on a machine.
Best money I ever spent on the truck. Very easy installation and the truck has never run smoother and quieter. I haven't checked the mpg yet but I can tell you that it is gonna be much better than the 10-11 I was getting with the Rochesters because I have about 60 miles on this tank and it off the full mark. With the Rochesters, I was getting 40-45 miles before it came off full.
The paperwork that came with the kit stated that this setup would work on engines up to 250cid with multiple carbs
Thruwurkin
Kennewick, WA
#61706 06/25/2006 5:16 AM
U
Junior Member
Junior Member
U Offline
Quote
Quote
[b] I have a 69 C-10 with a 250... Will the same replacements for the Rochester work on mine as well??
thanks!
- Joe
Thruwurkin
Kennewick, WA [/b]
I think that I'll keep my Rochester for now... I figured out my problem, it's something in the gas tank or the sending unit.
thaks for all your help guys.
- Joe
Stupid like a fox.
