Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Shade Baby, TexasFarmTruck, Dakota Bob, Shaffer's1950), 155 guests, and 6 robots.
Topics128,277
Posts1,058,442
Members48,490
#61626 06/11/2006 10:57 PM
I'm not sure what this hose does and there seems to be an adjustment on the side below the carb. http://members.shaw.ca/magnolia/What's-this.jpg
I'm trying to figure out why the vacuum from the carb that runs to the distributor isn't working. I have my carb tune-up kit but got a bit hesitant when I looked how complicated it was.
1958 Chevy 1/2 ton Apache Stepside Longbed
Never trust a driver with a collision shop courtesy car
Photo Album
#61627 06/11/2006 10:59 PM
So the link thing didn't work. Here's the pic (sig reduced in size) [img] http://members.shaw.ca/magnolia/What's-this.jpg [/img]
Photo Album
#61628 06/12/2006 12:39 AM
the link problem is prolly your use of Windows style file names - no ' might help the bolt script to accept it, or just put it in "bald":
http://members.shaw.ca/magnolia/What\'s-this.jpg
that's some PO's idea of a PCV setup, should be removed and a plug put in that manifold hole, which is where the vacuum wipers would hook up, as it's destroying the vacuum [that you're looking for grin ]
#61629 06/12/2006 3:17 AM
I have a similar setup on my '59 235. The PCV valve is showing between the two rubber hoses.
http://www.flickr.com/photos/11159813@N00/151949993/
I have not had any problems with this setup. The other vacuum line coming out of the T-fitting is for a under-dash installed vacuum gauge. This is where the vacuum wipers worked from also, until I changed to an electric wiper motor.
Adam
stovebolt2355
http://www.stovebolt2355.com
#61630 06/12/2006 4:29 AM
Adam - with the valve in there, if it's restrictive enough [and it'll prolly be plugged if it's not changed regular], you might not notice any problems, tho the vacuum would likely be less than it should be - the main problem is a PCV valve should come off the crankcase, not the valve cover, especially with a vented oil fill cap as Mike's appears to have [can't tell if his has a valve] - mostly what's happening is it's drawing air thru the valve cover from that vented cap, instead of drawing fumes/oil mist out of the crankcase as a PCV is meant to do, and a PCV should go to a metered vacuum port at the base of the carb
