4 members (TexasA&M48Truck, Mike B, 1955 1 Series, baldeagle), 121 guests, and 2 robots.
Topics128,026
Posts1,055,409
Members48,422
#61606 06/10/2006 6:53 PM
Junior Member
Junior Member
I've taken off the transmission cover to my '47 Chevy 3 speed to put on a new gasket and I am having trouble getting the linkage lined up again. My book says "With transmission gears in neutral and shifter forks in neutral position..."
The transmission was in neutral when I took the cover off but it doesn't appear to be anymore.
Can anyone tell me how to put the transmission in neutral and the shifter forks in the neutral position.
John M
#61607 06/10/2006 7:12 PM
The shift arms on the cover have 3 positions and are held on place with a spring and ball. The arms are in neutral when in the center position. The second/third fork has the small slot and needs to slide into the ring around the syncro drum. Slide the drum all the way to the front and then all the way to the back. Halfway between the 2 will be neutral. The other fork(first/reverse)slips over the first speed gear. Do the same as the other...all the way forward and all the way back and then halfway in between. Make sure the hump on the fork is nearest the rear of the transmission. When they are in the right spot the cover will go right on. Here's a link to a pic and more instructions in the shop manual. Good luck.
http://chevy.tocmp.com/1948_51truckshop/51ctsm0704.htm
Curt B.
You Tube
#61608 06/10/2006 8:41 PM
Junior Member
Junior Member
Awesome !
Thanks Curt !
~ Sheepish in Vt.
#61609 06/10/2006 11:15 PM
MtMan;
IB is correct. In case you need to know what the linkage arms look like when they are in various gears from the outside of the cover, check out my tranny rebuild pics on this link.
http://community.webshots.com/user/geezer
Country Roads, West (By God) Virginia
#61610 06/12/2006 1:01 PM
Junior Member
Junior Member
Thanks guys.
