3 members (BC59, dt235sd, Wooley),
124
Mod | | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Has anyone done this and how? Are there adapter kits available so a dual setup can be achieved?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Sep 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 77 | link to another post The above is how I did my Dad's 46 dual conversion. There should be a pics hyperlink in that post that show how I modified the bracket. Hope this helps. | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | I did it to my 58 - you can get the complete kit on ebay or through most parts guys LMC etc.
I upgraded to power brakes - drum/drum. Bolted right in - had to drill 1 hole.
The only issue I had was I had to remove the e-brake cables to make room - There is a pulley in the 58 that I need to push to the rear about 10 inches. Still haven't put it back in (its cold outside).
My kit re-used the existing brake pedal.
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I don't belive that you will find an adaptor kit for your 46. In order to keep your orig. pedal assembly you will need to fab a bracket to mount your dual master cylinder. It's not hard to do. If you send me an email I can sent you some pictures and a short write-up on how I did this on my 46. It's worth the effort IMHO. George [email protected] | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | George,
Excellent solution that doesn't distroy the original brake/clutch pedal bracket! I'll have that bracket fabricated and give "Lucille" a safer braking system. Your input is greatly appreciated!
