1 members (WICruiser), 209 guests, and 1 robot.
Topics128,102
Posts1,056,184
Members48,436
#615967 02/02/2010 8:49 AM
i need to get my truck back on the road. it has been too long since i have heard the glorious sound of the valves tapping away from the 216.
i need feedback! should i graft original timing gears or obtain new aluminum gears to resurrect my truck”s engine?
denny... help!
Check the gears for wear and alignment.If they look ok,use them.If you are concerned about their age,change them.
Drew
The steel crankshaft gear/fiber cam gear combination will be quieter, but the aluminum gears supposedly last longer. Unless you plan to put a lot of miles on the engine, the fiber gear should live a long time on a restored vehicle.
