1 members (Gray_Ghost),
83
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | i need to get my truck back on the road. it has been too long since i have heard the glorious sound of the valves tapping away from the 216.
i need feedback! should i graft original timing gears or obtain new aluminum gears to resurrect my truck”s engine?
denny... help! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Check the gears for wear and alignment.If they look ok,use them.If you are concerned about their age,change them.
Drew
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | The steel crankshaft gear/fiber cam gear combination will be quieter, but the aluminum gears supposedly last longer. Unless you plan to put a lot of miles on the engine, the fiber gear should live a long time on a restored vehicle. Jerry
