1 members (Southerntruck),
98
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | New challenge for me now that my truck has been on the road for 3 years. Several pieces of chrome on my truck have started to rust--specifically the tail-light brackets and the antenna brackets. I purchased these pieces from our usual sources--LMC, Chevy Duty, etc- so I tried not to get poor products via low prices. I am not a big fan of wax and polish on my vehicles, but I do keep them washed, especially the 57. I have never polished or waxed the 57. Is this my problem ??, If not, what is ? | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Personally it sounds like the parts had a cheap chrome job to begin with. I have seen chrome parts that held their polish for decades w/out rusting. Heck my stock bumpers on my project only have rust in the areas that have a scrape/damage & the rest of bumper shines...Joe | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | How bad are the rust spots? can you wipe them off with a rag? You might try some (0000)4 ott steel wool.Try it in an inconspicous(big word) place first to make sure it does'nt scratch the chrome,OR,you can use coke and aluminium foil.It really does work. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Try Simichrome Polish. It is costly but it works. A little dab will do ya. I used it on the grille of my '54 GMC and was amazed. It leaves a protective coating too. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | You can't keep cheap chrome from rusting. Using a polish / wax will slow the rusting down but the end result will appear....small rust pits. So keep polishing it, so it looks as good a it can be, but the bottom line is if you want it to look like chrome it has to be good chrome to start with. I think good chrome is more money than the manufactures of products today want to put into their product. Mainly because they look for ways to lower input cost so the bottom line looks better, and we the consumer can barely tell the difference when the chrome product is new. It just doesn't last as long before it's true color shows up...rust.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I was about to toss my old 55 door handles do to rust spots. Took some steel wool and it looks almost new! But I do have some new chrome pieces from the same manufacturers and I fear that I will be facing the same situation in a year or two. I just plan on polishing and keeping the truck out of the rain if at all possible in Florida! | | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | Russ............. Chrome plating is only a few Microns thick at the best of times. ANY abrasive cleaner will thin out this layer very quickly and only exacerbate the problem. Old chrome is thick and heavy with a good layer of base metals under the chrome top layer.These will handle a bit of polish, but over time will still degrade to a thin coppery color as the chrome layer is polished away. The best way to protect chromework is with a good wax/polish cleaner. The idea is to protect the very thin top layer of chrome from the elements by a layer of wax. This gets deep into the outer layer and prevents the underlying metals from contamination.
Unfortunatly, if you have newer, cheap chrome, not much can be done to prevent this process from happening.
Good Luck! | | |
