5 members (52Carl, Oswald, KEVINSKI, 1955 1 Series, 1 invisible), 374 guests, and 5 robots.
Topics128,164
Posts1,057,081
Members48,463
In planning to re cive my truck being that i disassemble it years ago i am unsure what goes on the fram most of the major components are still there but im not sure what is and what isnt i have a chevorlet factory assembly manual but my truck is a gmc also im unsure how to read it can i get osme help thanks attaboy
Your Chevrolet manual will work for most of the GMC parts. Just look at the book and look at the truck, I bet you will figure it out pretty quick. The small stuff will give the biggest problems. Just remember that and you will have it licked in no time.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
What year is your truck? What model is your truck?
There are three variations of the GMC grill on 1/2-tons alone '47 to '54. I think I can find a diagram of the '54-'55 1st version if that would help.
Also readint the assembly manual I found the right
Frame picture is there a way to corrilate that frame picture to the rest of the truck
I mean from sections numbers or something.
Also I have a maintinace manual any other litaratur I need
Its a 1953 GMC 1/2 ton standard cab 228 engine the gas tank behind the seat
I'm not sure of the Id numbers but I'm planning on getting all that when the truck gets here (by the way I don't know what id numbers
I need engine,frame,vin,etc.
and where to find them what information
is good to keep and where do I get it
any help is appreciated thanks.attaboy
I will never disassemble another vehicle without taking pictures! I got a cheap digital camera and document everything. I did get a service manual for my old beater and that helped, but sometimes I would get something partially assembled only to find that I had missed a part (or assembled cockeyed).
My advise is to "test-fit" stuff to make sure you have it correct before you do any final torquing of parts.
Good luck!
Everything is different now...
