| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 91 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 91 | Sorry about another engine ID question but here goes. Block casting 3769925 serial 28608 date code E 2 6 If the date code reads May 2 56 then it doesn't seem to jive with the block casting.This could be a canadian pontiac block, I see the pin hasn't been pushed in for the full flow filter.Just trying to narrow down the year. The head is an 848 with date code D 20 9. Thank you Mike | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy obrien1952gmc, according to Inlers Internationals web site, that casting number is from a 1958 - 62 261 Chev engine, hope that helps. | | | | | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | That date code could also be Mat 2 66 since these blocks were cast into the 70's as replacements. That might explain the non-standard "serial".
Joe D. | | |
