5 members (Rich'sToys, Hanks custodian, Hotrod Lincoln, ndkid275, Wally / Montana), 93 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
Couldn't figure this one out in past threads:
Are the 1/2 ton and 3/4 ton cab mount shackles interchangeable?
Might someone have a pic of a 1/2 ton shackle?
Dave
The attachment piece for these shackles is what is different on the frame. 3600 shackles, 4000, 6000 Series are all the same with the holes in vertical alignment. The 3100 shackle has an offset bolt pattern, here is a picture of the 3600 type. I do not have a picture of the offset or cabover (unique style)but they are shown in the 1947-54 Factory Assembly manual.
http://community.webshots.com/photo/2275285170102454676BEQvTZ
are the dimensions the same other than the bolt pattern?
does anyone have a picture of their 1/2 ton shackles?
Dave
I believe they are and the offset is only on the frame leg the cab side is the same for everything except the 5000 series COE.
Thanks, Brad, you wouldn't mind telling me the bolt hole dimension for the cab side would you? Is it about 2 1/4?
Dave
By the way, you've got a great set of pics on your webshots page.
Dave
