| | | Forums66 Topics128,141 Posts1,056,780 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Couldn't figure this one out in past threads:
Are the 1/2 ton and 3/4 ton cab mount shackles interchangeable?
Might someone have a pic of a 1/2 ton shackle?
Dave
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The attachment piece for these shackles is what is different on the frame. 3600 shackles, 4000, 6000 Series are all the same with the holes in vertical alignment. The 3100 shackle has an offset bolt pattern, here is a picture of the 3600 type. I do not have a picture of the offset or cabover (unique style)but they are shown in the 1947-54 Factory Assembly manual. http://community.webshots.com/photo/2275285170102454676BEQvTZ
| | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | are the dimensions the same other than the bolt pattern?
does anyone have a picture of their 1/2 ton shackles?
Dave
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I believe they are and the offset is only on the frame leg the cab side is the same for everything except the 5000 series COE. | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Thanks, Brad, you wouldn't mind telling me the bolt hole dimension for the cab side would you? Is it about 2 1/4?
Dave
| | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | By the way, you've got a great set of pics on your webshots page.
Dave
