3 members (chemanic, Otto Skorzeny, Mike Roache), 76 guests, and 2 robots.
Topics128,135
Posts1,056,418
Members48,441
Good afternoon gentleman. Can you identify this carb? I need a throttle cable holder for it and I am not sure what model it is. It has a "B" on the body, with MOD 10-412
it also has 102-105 on the other side.
http://www.flickr.com/photos/45902442@N05/4317373196/ Flicker Photo Page
Wow, that is a pretty pristine looking engine. I would be reluctant to run it and get it all dirty!
1951 1 Ton Completed
Thanks, NO, NO.. I really want to drive it! You should have seen it before, so now it is super clean according to what it used to look like. Thanks for the kind comments! I bought a model 48 radio off of Ebay and it looks just one of those you have there, appearently it is a Canadian GM model. I am looking into getting it working again. Hopefully I will be driving it this summer if all goes well.
Carburetion specialist
Rayfield model N.
This carburetor was sold as a price leader under a number of different names including Johnson and Marvel-Schebler through the various discount mail order auto parts stores. Borg-Warner had purchased several of the lesser carburetor companies, and marketed products through each companies previous avenues.
Good luck on finding any parts. If you really must use this unit, would suggest fabricating what you require. However, if you wish to look, there is probably an identification number STAMPED on the airhorn in the format 10-nnnn where nnnn is a four digit number. While the design is Rayfield, the numbering will be Marvel-Schebler.
Jon.
The Carburetor Shop
Thank you very much Ray!
woops, I mean Jon... I had Rayfield on the brain, sorry.
John, I have some different cable holders that came off of Stromberg carbs that might be modified to work for your throttle holder. If that would be of any help. (??)
53John,
I just noticed your comment about the radio. If you let me know the model number, I probably have the manual including installation instructions. The Canadian radios had a dual output stage that produced twice the output power of the normal AD radio.
Fred
So that's the reason for the extra tube socket hole in the chassis of the two straight back radios I did a while back.
Verrry interesting!
DG
Denny G
Sandwich, IL
