1 members (Hotrod Lincoln),
112
Mod | | | Forums66 Topics128,142 Posts1,056,491 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 164 | Good afternoon gentleman. Can you identify this carb? I need a throttle cable holder for it and I am not sure what model it is. It has a "B" on the body, with MOD 10-412 it also has 102-105 on the other side. http://www.flickr.com/photos/45902442@N05/4317373196/ Flicker Photo Page
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wow, that is a pretty pristine looking engine. I would be reluctant to run it and get it all dirty! | | | | | Joined: Dec 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 164 | Thanks, NO, NO.. I really want to drive it! You should have seen it before, so now it is super clean according to what it used to look like. Thanks for the kind comments! I bought a model 48 radio off of Ebay and it looks just one of those you have there, appearently it is a Canadian GM model. I am looking into getting it working again. Hopefully I will be driving it this summer if all goes well. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Rayfield model N.
This carburetor was sold as a price leader under a number of different names including Johnson and Marvel-Schebler through the various discount mail order auto parts stores. Borg-Warner had purchased several of the lesser carburetor companies, and marketed products through each companies previous avenues.
Good luck on finding any parts. If you really must use this unit, would suggest fabricating what you require. However, if you wish to look, there is probably an identification number STAMPED on the airhorn in the format 10-nnnn where nnnn is a four digit number. While the design is Rayfield, the numbering will be Marvel-Schebler.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Dec 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 164 | | | | | | Joined: Dec 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 164 | woops, I mean Jon... I had Rayfield on the brain, sorry. | | | | | Joined: May 2005 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 45 | John, I have some different cable holders that came off of Stromberg carbs that might be modified to work for your throttle holder. If that would be of any help. (??) | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 53John, I just noticed your comment about the radio. If you let me know the model number, I probably have the manual including installation instructions. The Canadian radios had a dual output stage that produced twice the output power of the normal AD radio.
Fred | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | So that's the reason for the extra tube socket hole in the chassis of the two straight back radios I did a while back. Verrry interesting! DG
Denny G Sandwich, IL
