| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61542 06/09/2006 2:47 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I had to remove the Manifolds over the weekend to replace a broken exhaust stud. The tail pipe wasn’t connected properly and all the exhaust was going into the cab, I also replaced the thermostat for the hell of it.
Anyhow I was running the engine to warm it up (with out the radiator cap) and now that the tail pipe to flange is sealed I notice a little smoke coming out of the valve cover oil filler cap. It wasn’t a lot but it was enough to notice it faintly in the sun light glare.
What causes this? Excessive gas vapors? Or is this normal? New manifold gasket?
Thanks Billy | | |
#61543 06/09/2006 3:06 PM | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | Vapor out of the valve cover is a normal thing for any engine, as long as its just a little. The PCV valve will suck these back into the engine if its hooked up and working right. The draft tube of the older engines release this vapor out under the vehicle. Since the rings cannot seal 100%, a small amount of compression gets by which mixes with oil and becomes the vapor you see. Joe | | |
#61544 06/09/2006 3:11 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Billybolt, Unless You added a pcv or Your draft is not stopped up, I would not think a little whiff of smoke caught in the sunlight would be of any concern. Someone with more experience than me (Wrenchbender Ret.) or others. Joe H beat me too the post
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | |
#61545 06/09/2006 3:17 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Thanks Joe, My 235 doesn't have the down draft tube, I did clean out the PVC valve while I was cleaning the manifold. The old fittings were nearly clogged it only had a pinhead size opening. I didn’t think it even needed a PVC valve, I guess I will replace that while I am at it.
I kind of figured it was normal. I was used to this on the old air cooled VW engines. I used to be a VW guy until I saw the light. | | |
#61546 06/09/2006 5:01 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Just to make sure things are correct…I have a hose going from the valve cover to the side of the intake manifold that has a PVC valve in line with it. | | |
