| | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | I just bought four 8 lug 16 inch rims for my 48 3/4 ton chev. The rims are off early 80s chev truck. The front rims just barely hit the tie rod. I have a guy that will plasma cut me a spacer from 3/16 or 1/4 inch metal that i can put right over the studs, basically a ring with holes in it.he will do the job for $50. Does anybody have any thoughts on this. Is there something else I should do? Thanks, FREEZING UP HERE IN MINNESOTA | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You can buy them from FLAPS for less than $50.
| | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | favourite local autoparts store | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Friendly local auto parts store. | | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | Thanks alot, Can you tell i am a newbie? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not until you ask what AD stands for, every newbie has to ask that. Try a Google search and you can choose from hundreds of suppliers. All you have to be careful of is that you still have full engagement of the nuts with the spacer in place. If not then you will need to replace the studs with longer ones. Here is one to start you off; http://www.ezaccessory.com/Wheel_Spacers_s/27.htm DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | Thank you, I orderd them and they should be here wednesday. | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Try a wheel shop . I was going to have them made also and happened to be at a shop that sold custom wheels. He had some in different thickness . They were about $ 8.00 each. Been on for 5 years now clears 16x8 rims with P255/70r16 on them. | | |
