2 members (Hotrod Lincoln, 1 invisible),
137
Mod | | | Forums66 Topics128,196 Posts1,057,385 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I'm in the planning stage of building a 1966 GMC heavy-duty 1-ton(maybe a 1-1/4 ton?) crew cab dually. I want to use a 478 GMC v-6, a fuller FSO-6406a 6-speed manual O/D transmission, a dana 70hd or dana 80 rear(with 3.55, 3.73, or 4.11 gears). Because the 478 weighs a lot(925 lbs dry!) I wanted to know if a 73-91 1-ton coil spring suspension and frame are stout enough for this engine and trans. If not, I would like to know if a p-30(?) front suspension and frame would be sufficient using either the coil or leaf spring front end. I've been partial to the 19.5" wheel with the 5/10 lug on 7.25" pattern, but it's not absolutely necessary. I'm looking at using 32-33" diameter tires. I want to use this rig strictly for towing 22,000 or less pounds cruising around 65-75 mph on flat land. I plan to use this rig to replace my 86 chevy crew cab 1-ton dually that has a 454, th400, 4.11 rear. The bottom line is that I want an older GMC equivalent(more or less) of a new f-450 pickup. Any help or advice is greatly appreciated.
Mike
Long live the V-6!! | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You've posted the same question in both big bolts and here. That's going to confuse simple minded folk like me...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | That's true, you know what they say: You'll get more bites if you put more lines in the water. | | | | | Joined: Dec 2009 Posts: 48 Apprentice | | Apprentice Joined: Dec 2009 Posts: 48 | Did they make such a thing from the factory? (Maybe a '66 1-ton 4x4 crewcab?)
'76 F-350 Super Camper Special (140" WB), Ranger-XLT, Fast 390 V8, 4-Speed, Gun Rack, Brush Guard, Dual Exhaust, 3.73 Gears, 10K GVW. '74 F-250 Super-Cab (155" WB), Ranger, Rebuilt 390 V8, C6 Auto, Tachometer, Headers, '77 Grille, Kill Switch, Single Exhaust, 4.11 Gears. '59 Chevy 38 Apache Stakebed (Not running), 235-Inline-6, 4-speed, Gun Rack, 3 Tanks, Dual Rear Wheel, 9.5K GVW & no fancy stuff. '99 Mitsubishi Fuso 5-Ton Delivery Truck, Diesel, 4-Speed Auto, 1-Ton Lift Gate, 18FT Box.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Did they make such a thing from the factory? No, when you see a truck that old with four doors it was build by some coach builder or customizer. There used to be quite a few companies building that kind of thing for commercial use. The first factory built GM crew cab was the '73 3+3 or Bonus Cab. I used to see one around here all the time and I told the owner when he was done with it I wanted it. I was going to use parts of it on one of my projects. I haven't seen it in a long time so it may be gone.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 | According to my 1963 Chevrolet Silver Book: National Coaches Inc. Knightstown Indiana phone Stageway Coaches Inc. 519 North Ninth St. Fort Smith, Arkansas Proctor-Keefe Body Co.,Inc 7741 Dix Ave Detroit 9 Michegan Automotive Conversions Corporation 2191 Cole St. Birmingham Mi.
