7 members (Woodcmiami, UtahYork, TUTS 59, Shade Baby, Otto Skorzeny, frogfarmer, 1 invisible),
171
Mod | | | Forums66 Topics128,277 Posts1,058,443 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Guys, looks like I need new door mechanisms. This winter, my doors don't work well anymore. I'll go around a corner and the door will suddenly fly open, and then it's like things are frozen inside and it's very hard to relatch. Sometimes it will and sometimes it won't. Otherwise my 52 GMC 3/4 ton runs fine. The striker plates are also so worn that they don't allow the door to fully close anymore.
Who has a good source for latches and striker plates? Any suggestions?
Thanks.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Have you tried re-adjusting the striker plates? Then the door hinges? Most after marketers like Jim Carter sell replacement parts.
Drew
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Also when the door flies open the latch mechanism will usually be in the first catch position. Make sure it is fully open before you slam it shut again. First I would remove and clean all the parts and apply a good lubricant in all the moving parts. If your strikers are worn out, replace them. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | The problem is that both the latch mechanisms and the striker plates on my doors are extremely worn out. A few years ago I welded in new material where the old metal on the striker plate was worn out, but that too has worn out. Yes, everything is adjusted as well as it can be, but the striker plate is so worn out that it won't hold the door very well. The mechanism also is so old that it doesn't spring back well and looses its holding ability over bumpy roads. The whole thing is just too darn old and needs a complete rebuild.
I'll check Jim Carter. Thanks. | | |
