| | | Forums66 Topics128,147 Posts1,056,798 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61469 06/08/2006 4:00 AM | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | does anyone know how much you can notch the oil pan above the front axle for more clearance on a ad truck? | | |
#61470 06/10/2006 11:35 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | drain oil, cut out pan bottom, measure to crankshaft & Rod caps, cut pan to fit, weld on. That will fix it. | | |
#61471 06/10/2006 11:48 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Don't forget to add a 2nd drain plug ahead of the notch so you can drain the oil from it. Ferd had to do that on the 302/351 in the fox body and ltd to clear the front crossmember. Lots of guys miss that plug when they change the oil.
Bill Burmeister | | |
