2 members (ndkid275, Southerntruck), 66 guests, and 2 robots.
Topics128,090
Posts1,056,374
Members48,442
#61469 06/08/2006 4:00 AM
does anyone know how much you can notch the oil pan above the front axle for more clearance on a ad truck?
1949 SUBURBAN
#61470 06/10/2006 11:35 PM
drain oil, cut out pan bottom, measure to crankshaft & Rod caps, cut pan to fit, weld on. That will fix it.
#61471 06/10/2006 11:48 PM
Don't forget to add a 2nd drain plug ahead of the notch so you can drain the oil from it. Ferd had to do that on the 302/351 in the fox body and ltd to clear the front crossmember. Lots of guys miss that plug when they change the oil.
Bill Burmeister
