3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#614589 01/29/2010 2:21 AM
Hi:
Installed a "Standard" three terminal horn relay for for a 49 panel truck but there are no instructions on how to wire it up. Has anyone installed one of these and if so what wire goes to what terminal?Further, does one of the wires on the horn connect directly to a ground source or does it go back to the relay. Thanks in advance for the answers, I appreciate it.
God bless,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
A49ER #614607 01/29/2010 3:24 AM
That year didn't have a horn relay. Do you have the orginial horn? The relay didn't come about until 1953.
AD_Pickup #614611 01/29/2010 3:34 AM
My 51 came with a horn relay. One terminal is the main power and it connects to the battery lead at the starter. Another terminal is the ground end of the coil and it goes to your horn button. The third wire supplies power to the horn.
1951 1 Ton Completed
truckernix #614635 01/29/2010 4:32 AM
When looking at the horn relay from left to right
Left terminal + going to horn
Middle terminal + from truck side of amp gauge ( other side of amp gauge comes from generator)
right terminal - from horn button on steering wheel
- from horn to a ground near horn I put mine from terminal on horn to the bracket it's mounted on .
Pete
Pete52 #615217 01/31/2010 12:21 AM
Guys:
Thanks for the help, I appreciate it.
God bless,
Dave
A49ER #615855 02/02/2010 12:55 AM
Are most horn relays the same?
