| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Hi:
Installed a "Standard" three terminal horn relay for for a 49 panel truck but there are no instructions on how to wire it up. Has anyone installed one of these and if so what wire goes to what terminal?Further, does one of the wires on the horn connect directly to a ground source or does it go back to the relay. Thanks in advance for the answers, I appreciate it.
God bless,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | That year didn't have a horn relay. Do you have the orginial horn? The relay didn't come about until 1953. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My 51 came with a horn relay. One terminal is the main power and it connects to the battery lead at the starter. Another terminal is the ground end of the coil and it goes to your horn button. The third wire supplies power to the horn.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | When looking at the horn relay from left to right Left terminal + going to horn Middle terminal + from truck side of amp gauge ( other side of amp gauge comes from generator) right terminal - from horn button on steering wheel
- from horn to a ground near horn I put mine from terminal on horn to the bracket it's mounted on .
Pete | | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Guys:
Thanks for the help, I appreciate it.
God bless,
Dave
| | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Are most horn relays the same? | | |
