0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | chevy 235 con4 f151 behind starter. can anybody help | | | | | Joined: Dec 2009 Posts: 24 New Guy | | New Guy Joined: Dec 2009 Posts: 24 | I am sorry, I don't understand. What are you asking for? I'd like to help.
If it ain't a Chevy, It ain't nothin'.
| | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | i wanted to know what this motor came out of | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | block# is 3769716 head# is 3836848 does this help | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | We need the number that's stamped on the pad by the distributor. This gives the exact original application, as block castings could have multiple applications.
Bill Burmeister | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | number near and below distributor 3769716 | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3769716 = 58-64 block 3836848 = 56-63 head f151 is a block date casting code. Having the above information, the date is: f = June 15 = 15th of the month 1 = 1961 The page shows locations for all engine codes. Look for the head casting code. If what you posted, 3769716, is the engine serial number, information seems to be missing. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | number near and below distributor 3769716 That's the casting number. I'm looking for the serial number, which is in this location, and is a stamped number.
Bill Burmeister | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | is there a way to find out what this motor came out of
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As Bill posted, the only way to find out is to have an engine serial number. Look at Bill's link, above. Here is location shown at the link I gave, above. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | John,
The raised block casting number you posted 3769716 is below the distributor. Are you sure the number isn't 3739716 because that block casting was used in cars and trucks in 1961.
The number the guys are asking for is a stamped number on a flat machined area just to the left of the distributor. You have to clean off the crude to see it.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3769716 and 3739716 have been listed by various sources as both being used in 1961 (1958-1963).
If you cannot find an engine serial number, and if those block codes were used in trucks and cars, you would have to check the lifters to see if it was a truck engine (mechanical lifters) or a car engine (hydraulic lifters).
The engine serial number should give more information about the model of the vehicle the engine come in.
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | I think trucks started with that casting # in 1960 with date codes thru 1962.
Cars, both with standard and powerglide trans, in 1958 with date codes thru 1962.
-Tom
| | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 235, 135 horsepower, Flint plant, built June 19th, Passenger car application w/hydralic lifters.
Bill Burmeister | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes. Should work just fine.
