7 members (Otto Skorzeny, J Lucas, dt235sd, Cosmo, jeffreyguy, Charles in CA, LAROKE), 132 guests, and 6 robots.
Topics128,107
Posts1,056,221
Members48,436
#614564 01/29/2010 1:46 AM
chevy 235 con4 f151 behind starter.
can anybody help
1 Offline
I am sorry, I don't understand. What are you asking for? I'd like to help.
If it ain't a Chevy, It ain't nothin'.
i wanted to know what this motor came out of
block# is 3769716 head# is 3836848 does this help
We need the number that's stamped on the pad by the distributor. This gives the exact original application, as block castings could have multiple applications.
Bill Burmeister
number near and below distributor 3769716
other number b24 48
860
3769716 = 58-64 block
3836848 = 56-63 head
f151 is a block date casting code.
Having the above information, the date is:
f = June
15 = 15th of the month
1 = 1961
The page shows locations for all engine codes. Look for the head casting code.
If what you posted, 3769716, is the engine serial number, information seems to be missing.
That's the casting number. I'm looking for the serial number, which is in this location, and is a stamped number.
Bill Burmeister
is there a way to find out what this motor came out of
As Bill posted, the only way to find out is to have an engine serial number. Look at Bill's link, above.
Here is location shown at the link I gave, above.
John,
The raised block casting number you posted 3769716 is below the distributor. Are you sure the number isn't 3739716 because that block casting was used in cars and trucks in 1961.
The number the guys are asking for is a stamped number on a flat machined area just to the left of the distributor. You have to clean off the crude to see it.
-Tom
1950 Chevy 3100 w/ 1956 235
3769716 and 3739716 have been listed by various sources as both being used in 1961 (1958-1963).
If you cannot find an engine serial number, and if those block codes were used in trucks and cars, you would have to check the lifters to see if it was a truck engine (mechanical lifters) or a car engine (hydraulic lifters).
The engine serial number should give more information about the model of the vehicle the engine come in.
I think trucks started with that casting # in 1960 with date codes thru 1962.
Cars, both with standard and powerglide trans, in 1958 with date codes thru 1962.
-Tom
found it fo619a
235, 135 horsepower, Flint plant, built June 19th, Passenger car application w/hydralic lifters.
Bill Burmeister
is this a good motor
Yes. Should work just fine.
Bill Burmeister
thanks longbox
