4 members (frogfarmer, BillCollins, VicZ, oldsteve), 111 guests, and 0 robots.
Topics128,087
Posts1,055,974
Members48,430
#613568 01/26/2010 4:02 AM
Folks I'd like to change to a 3:90 59 apache rear end in a 1952 chevy 1/2 pickup.I'd like to make the same change to a 1952 1/2 GMC pickup .Is there any thought that either or both will not work.Help and thanks in advance.Sid Stephenson
3B Offline
Hy sidsoldtrucks, were you going to swap the entire axle or just transplant the center sectio? If I am remembering correctly, swapping just the center section should be no problem in either case, you will end up needing a driveshaft, and a transmission for an open drive setup, hope that helps.
4.11 to 3.90 is not much of a change. Are you swapping for an OD transmission?
Do you have a 59 parts truck, or do you just have the rear end. If you have only the rear end, you will need an open drive shaft transmission and a drive shaft. Whatever works on your Chev will also work on the GMC.
On this same topic - anyone know what late model pickups make a good donor for a rear end? I know that Mazda, Nissan and Isuzu have the same 6 lug pattern, but I have no clue on the rear end widths or the gears in them
thanks!
- Joe
stupid like a fox
art and junk: sandiegojoe.com
SDJoe - I used a '78 full size Blazer rear end in my '50 3100 (Walter) and it worked very well. It is very close to the orginal width and it has the same 6 lug pattern as the original. We just needed to weld new spring pads and, of course, change over to an open driveshaft transmission. For what it's worth...
