8 members (mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, homer52, 1 invisible),
102
Mod | | | Forums66 Topics128,089 Posts1,056,137 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 27 | Folks I'd like to change to a 3:90 59 apache rear end in a 1952 chevy 1/2 pickup.I'd like to make the same change to a 1952 1/2 GMC pickup .Is there any thought that either or both will not work.Help and thanks in advance.Sid Stephenson | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy sidsoldtrucks, were you going to swap the entire axle or just transplant the center sectio? If I am remembering correctly, swapping just the center section should be no problem in either case, you will end up needing a driveshaft, and a transmission for an open drive setup, hope that helps. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 4.11 to 3.90 is not much of a change. Are you swapping for an OD transmission? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Do you have a 59 parts truck, or do you just have the rear end. If you have only the rear end, you will need an open drive shaft transmission and a drive shaft. Whatever works on your Chev will also work on the GMC. | | | | | Joined: Mar 2008 Posts: 10 New Guy | | New Guy Joined: Mar 2008 Posts: 10 | On this same topic - anyone know what late model pickups make a good donor for a rear end? I know that Mazda, Nissan and Isuzu have the same 6 lug pattern, but I have no clue on the rear end widths or the gears in them
thanks! - Joe
stupid like a fox art and junk: sandiegojoe.com
| | | | | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | SDJoe - I used a '78 full size Blazer rear end in my '50 3100 (Walter) and it worked very well. It is very close to the orginal width and it has the same 6 lug pattern as the original. We just needed to weld new spring pads and, of course, change over to an open driveshaft transmission. For what it's worth... | | |
