7 members (D B Cooper, 55shaker, GMCJammer51, MickeyP, ndkid275, Phak1, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61436 06/07/2006 2:57 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Hey guys, I hope this isn't too much of a rookie question.
Is their a torque setting for the exhaust manifold on a 235? And also exhaust manifold to intake manifold?
It on a 59 | | |
#61437 06/07/2006 3:14 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The center clamp bolts torque to 15-20 ft lbs. and the outers are 25-30 ft lbs. I couldn't find a spec for the bolts that connect the 2 manifolds together at the heat riser. I suggest replacing the 2 dowells at the outside ends of the exhaust manifold with bolts/studs. It really helps with any leaks in the manifold gasket.
Bill Burmeister | | |
#61438 06/07/2006 3:22 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Thanks LONGBOX I think the dowels have been replaced, mine has bolts all across the manifold.
Billy | | |
#61439 06/07/2006 3:42 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I should also add that you wiil most likely need a crowsfoot adapter to get to the inner bolts. Especially if you're running an aftermarket intake. It's somewhat tight in there for a socket.
