4 members (Gdads51, mick53, KEVINSKI, FAST55), 87 guests, and 2 robots.
Topics128,090
Posts1,056,018
Members48,430
#61436 06/07/2006 2:57 PM
Hey guys,
I hope this isn't too much of a rookie question.
Is their a torque setting for the exhaust manifold on a 235?
And also exhaust manifold to intake manifold?
It on a 59
The center clamp bolts torque to 15-20 ft lbs. and the outers are 25-30 ft lbs. I couldn't find a spec for the bolts that connect the 2 manifolds together at the heat riser. I suggest replacing the 2 dowells at the outside ends of the exhaust manifold with bolts/studs. It really helps with any leaks in the manifold gasket.
Bill Burmeister
Thanks LONGBOX
I think the dowels have been replaced, mine has bolts all across the manifold.
Billy
I should also add that you wiil most likely need a crowsfoot adapter to get to the inner bolts. Especially if you're running an aftermarket intake. It's somewhat tight in there for a socket.
Bill Burmeister
