8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Hello all
I am about to recondition my 43 GMC electrical wiring and have found the proper cloth wire and loom.
The last part is the connectors. I am looking for flag style, loop type.for many of the terminal connections.
I found one size, for 28-31 Fords (Macs Antique Auto parts) but will need to go down to 8ga wire, they only list a single terminal size for 10-16ga.
Anyone know of a source of these buggers?
Thanks in advance. | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 |
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | <CLICK> The downside is they have a $20 minimum order unless you're a previous customer.
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Those are what I believe are called butt type(?).
The ones on the older harneses are 'loop type'. The wire is held on by two metal tabs, not one large one.
The ones from that catalog can be found 50/$3. The loop type are $.50 each.
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Are the terminals used on 63 trucks also?
I bought the terminals for my 63 from Hillco.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jul 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 93 | This company has some. www.riwire.com They are called "Flag Spade Terminals". | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | This company has some. www.riwire.com They are called "Flag Spade Terminals". This is where I ordered my braided wire from. Their terminals are wrong WRT my 43 GMC. Evidently the loop type flags have been superseded by the 'butt' type. I am going to try and get some of the butt type and see if I can mill the crimp type with a slot to get the proper look. Since these are stamped parts, getting a custom job done for a few dozen wold be way to much money. Plus you would need about 4-6 different sizes to cover the hole and wire gauge size. I'll post pics of what I get after I cut some up. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Here is a pic of the loop type flag. http://www.tm9-801.com/forums/download/file.php?id=154Note the gap between the 'tongs'(?) or fingers... that's the magical characteristic for the older harnesses. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Item #11 in the link I posted is probably as close as you'll get these days. You can probably reuse the old connector. I have several times.
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Item 11 is nothing special. They are like $3 for a box of 10 at any electronics store  I found a place that has the loop style... but they have not returned my e-mail. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Hey farber, why don't you just post the places that your finding this stuff and quit dangling the bait in front of us! If you know where to get all this oriiginal looking electical connectors then let the rest of us guys in on it. Denny Graham Sandwich, IL Did you read the first post? "I found one size, for 28-31 Fords (Macs Antique Auto parts) but will need to go down to 8ga wire, they only list a single terminal size for 10-16ga." Heres the direct link from their catalog: Flag post | | |
