9 members (Tronman, tclederman, Bill Hanlon, Otto Skorzeny, Hotrod Lincoln, carbking, 49choptop, Guitplayer, John L.), 145 guests, and 4 robots.
Topics128,042
Posts1,055,501
Members48,424
Hello all
I am about to recondition my 43 GMC electrical wiring and have found the proper cloth wire and loom.
The last part is the connectors. I am looking for flag style, loop type.for many of the terminal connections.
I found one size, for 28-31 Fords (Macs Antique Auto parts) but will need to go down to 8ga wire, they only list a single terminal size for 10-16ga.
Anyone know of a source of these buggers?
Thanks in advance.
I'd love to know too.
Bryan
1954 3104 235 "AD" L-6 3-on-the tree
Ex Hall Monitor
Ex Hall Monitor
<CLICK> The downside is they have a $20 minimum order unless you're a previous customer.
Those are what I believe are called butt type(?).
The ones on the older harneses are 'loop type'. The wire is held on by two metal tabs, not one large one.
The ones from that catalog can be found 50/$3. The loop type are $.50 each.
Are the terminals used on 63 trucks also?
I bought the terminals for my 63 from Hillco.
Larry
I don't own a vehicle that isn't old enough to drink.
This company has some. www.riwire.com They are called "Flag Spade Terminals".
This is where I ordered my braided wire from. Their terminals are wrong WRT my 43 GMC.
Evidently the loop type flags have been superseded by the 'butt' type.
I am going to try and get some of the butt type and see if I can mill the crimp type with a slot to get the proper look.
Since these are stamped parts, getting a custom job done for a few dozen wold be way to much money. Plus you would need about 4-6 different sizes to cover the hole and wire gauge size.
I'll post pics of what I get after I cut some up.
Here is a pic of the loop type flag.
http://www.tm9-801.com/forums/download/file.php?id=154
Note the gap between the 'tongs'(?) or fingers... that's the magical characteristic for the older harnesses.
Ex Hall Monitor
Ex Hall Monitor
Item #11 in the link I posted is probably as close as you'll get these days. You can probably reuse the old connector. I have several times.
Item 11 is nothing special.
They are like $3 for a box of 10 at any electronics store frown
I found a place that has the loop style... but they have not returned my e-mail.
Hey farber, why don't you just post the places that your finding this stuff and quit dangling the bait in front of us! If you know where to get all this oriiginal looking electical connectors then let the rest of us guys in on it.
Denny Graham
Sandwich, IL
Did you read the first post?
"I found one size, for 28-31 Fords (Macs Antique Auto parts) but will need to go down to 8ga wire, they only list a single terminal size for 10-16ga."
Heres the direct link from their catalog:
Flag post
