4 members (Hotrod Lincoln, FishinToms53, Bill Hanlon, Charles in CA), 71 guests, and 3 robots.
Topics128,087
Posts1,056,000
Members48,430
#613722 01/26/2010 4:54 PM
Can someone tell me what the approximate thickness of the brake pad should be on "new relined" huck type shoes? Just want to understand how bad my brake shoes are currently.
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
Lucille #613727 01/26/2010 5:53 PM
Lucille The new ones i have here are aprox .278 thik and are bonded.This is just the lining.mine wher done at OTT'S Friction Supply, Portland Oregon. The original lining was rivited and .187 thick . You should check you're drum diameter.As far as how thin the lining can get YOU'RE CALL. But new lining is cheep as compared to new/ used drums. I do not know how over thick/ size they can go. go here - http://chevy.oldcarmanualproject.com/index.htm. Much good info.
T-RUCK #613760 01/26/2010 7:45 PM
T-RUCK, holy smokes, my pads are barely 1/8" thick! Will get mine relined for sure! Thanks for the info!
BTW, can someone suggest a reliable place where I could send my brake pad mounts to get relined?
If not, is Uncle Alvin around? There must be a reliable place locally that would do this for me? Right? Or do I have to send them out?
David Wolff
1946 Chevy 1/2-ton
Lucille #614044 01/27/2010 5:14 PM
There will be a place nearby that services heavy truck brakes. Probably has "Friction" in the name... They will reline all sorts of brakes, install new springs, whatever. I had mine done at a truck and equipment brake and clutch place in Edmonton. If you can, ask at a few places and get prices. All 4 wheels for Big Blue cost me $185 cdn, several years ago.
Good luck.
