8 members (ShopRag, cmayna, moparguy, Gdads51, SNOYL, Hush, Gray_Ghost, Bill Hanlon), 173 guests, and 0 robots.
Topics128,114
Posts1,056,283
Members48,439
#612386 01/22/2010 4:39 PM
Guys,
1954 3100 w/ 235
I'm looking for a vendor who sells the brass fitting that screws into the intake manifold and provides vacuum to the windshield wiper motor. I think it's about 1/2" pipe thread with a 90 degree turn into a hose barb fitting. When I got my truck it had been altered and had a short piece of galv. pipe sticking out....
Pictures of yours would also be helpful if you believe yours to be stock...
Bryan
1954 3104 235 "AD" L-6 3-on-the tree
My stock fitting got broken. I made up a new one that goes from the pipe thread in the manifold to a piece of steel line that I attach the hose to.
1951 1 Ton Completed
truckernix #612395 01/22/2010 5:15 PM
I'm assuming that's what happened to mine, ol' farmer fred fixed it by screwing in a piece of pipe, capped the end, and drilled and tapped the cap to accept a compression fitting with a short piece of copper line that the rubber line slips over.....
Again.... anyone know of some one who sells this fitting or do I need to try McMaster Carr?
Bryan
Try the plumbing department at any of the big box home improvement stores, Home depot, etc. What you need is called a "pipe to tubing street ell" in brass. It will have a male pipe thread, and a hose barb on the other side of the 90 degree fitting. Some stovebolt manifolds have a 1/4" pipe thread in the manifold, while others will have a 1/2" pipe thread. The bigger rigs with Hydrovac brake boosters used the big vacuum fitting, while the ones with only vacuum wipers used the small one.
Apprentice
Apprentice
I find by far the best place to get this stuff is Ace Hardware. They have a great selection of brass fittings in the plumbing department. By far greater selection than Home Depot, etc.
squarenutz #612953 01/24/2010 4:10 PM
Y
Y Offline
Try orscheln's or tractor supply, They sometimes have this stuff, If you want one that is straight and not a 90
Kansas City Valve and Fitting has them(not stock but they can order them) they are $3.30 or close to that, the part number is b-4-hc-1-2 for 1/4" id hose, 1/8 pipe thread, or b-3-hc-1-2 for 3/16 id hose around $4.00. that is where I get my replacements (on my 1 ton and 1.5 ton)
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Yelostn78 #612966 01/24/2010 4:53 PM
try MacMaster Carr item # 53525K12 it's listed in barbed hose fitting section they have many sizes listed.
Pete
Pete52 #612981 01/24/2010 5:16 PM
Here's what I did on my 55.1 (pic)
I got it from either Home Depot or Lowes.
Its a brass bushing to reduce the 1/2" thread down to 1/4 (or 3/8) and then a hose barb elbow.
regards,
Leon
Leon #613350 01/25/2010 5:38 PM
OK....
I think the answer is, "nobody sells an accurate reproduction of the original elbow, so go find something that works."
thanks guys, helpful as always!
Bryan
Bryan
Apprentice
Apprentice
If I remember correctly, the "original elbow" looked like a standard hex-sided 1/2" pipe thread plug with a 1/4" tube sticking out of the middle and bend over gracefully to 90 degrees. If I could not find one at the junkyard, I would make one out of a standard 1/2" brass plug. Drill a hole in the top center of the plug, and insert and solder in a piece of 1/4" tubing pre-bent to 90 degrees. Once you hit it with a little black paint it will look original.
