1 members (Steelonsteel),
141
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | Guys,
1954 3100 w/ 235
I'm looking for a vendor who sells the brass fitting that screws into the intake manifold and provides vacuum to the windshield wiper motor. I think it's about 1/2" pipe thread with a 90 degree turn into a hose barb fitting. When I got my truck it had been altered and had a short piece of galv. pipe sticking out....
Pictures of yours would also be helpful if you believe yours to be stock...
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My stock fitting got broken. I made up a new one that goes from the pipe thread in the manifold to a piece of steel line that I attach the hose to. | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | My stock fitting got broken. I made up a new one that goes from the pipe thread in the manifold to a piece of steel line that I attach the hose to. I'm assuming that's what happened to mine, ol' farmer fred fixed it by screwing in a piece of pipe, capped the end, and drilled and tapped the cap to accept a compression fitting with a short piece of copper line that the rubber line slips over..... Again.... anyone know of some one who sells this fitting or do I need to try McMaster Carr?
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Try the plumbing department at any of the big box home improvement stores, Home depot, etc. What you need is called a "pipe to tubing street ell" in brass. It will have a male pipe thread, and a hose barb on the other side of the 90 degree fitting. Some stovebolt manifolds have a 1/4" pipe thread in the manifold, while others will have a 1/2" pipe thread. The bigger rigs with Hydrovac brake boosters used the big vacuum fitting, while the ones with only vacuum wipers used the small one. Jerry
| | | | | Joined: Apr 2006 Posts: 31 Apprentice | | Apprentice Joined: Apr 2006 Posts: 31 | I find by far the best place to get this stuff is Ace Hardware. They have a great selection of brass fittings in the plumbing department. By far greater selection than Home Depot, etc. | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | Try orscheln's or tractor supply, They sometimes have this stuff, If you want one that is straight and not a 90 Kansas City Valve and Fitting has them(not stock but they can order them) they are $3.30 or close to that, the part number is b-4-hc-1-2 for 1/4" id hose, 1/8 pipe thread, or b-3-hc-1-2 for 3/16 id hose around $4.00. that is where I get my replacements (on my 1 ton and 1.5 ton) | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | try MacMaster Carr item # 53525K12 it's listed in barbed hose fitting section they have many sizes listed.
Pete | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Here's what I did on my 55.1 ( pic) I got it from either Home Depot or Lowes. Its a brass bushing to reduce the 1/2" thread down to 1/4 (or 3/8) and then a hose barb elbow. regards, Leon | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | OK....
I think the answer is, "nobody sells an accurate reproduction of the original elbow, so go find something that works."
thanks guys, helpful as always!
Bryan
| | | | | Joined: Apr 2006 Posts: 31 Apprentice | | Apprentice Joined: Apr 2006 Posts: 31 | If I remember correctly, the "original elbow" looked like a standard hex-sided 1/2" pipe thread plug with a 1/4" tube sticking out of the middle and bend over gracefully to 90 degrees. If I could not find one at the junkyard, I would make one out of a standard 1/2" brass plug. Drill a hole in the top center of the plug, and insert and solder in a piece of 1/4" tubing pre-bent to 90 degrees. Once you hit it with a little black paint it will look original. | | |
