1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61279 06/03/2006 8:12 PM | Joined: Apr 2006 Posts: 53 Member | | Member Joined: Apr 2006 Posts: 53 | My 292 runs sweet but, Sometimes it will run on for about a two seconds after I turn the key off. Am I running to much advance? Its about 4 Degrees BTC. Idle speed is at 700 RPM. I did all my tuning using a vacum gauge. It does not do it all the time what gives? | | |
#61280 06/03/2006 9:35 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it,s a manual trans. slow thw idle down a little. Check for vacuum leaks. The Monojet carb. can wallow out the gasket between the throttle body & fuel bowl. You usually can see it from the outside. The timing doesn,t effect that unless it,s way off. You can usually run 6-8 advance on those & it will run better. If it pings set it back a little. If your spark plug heat range is to hot it can cause that. If you can,t fix it get a idle selenoid from a 6 cyl. car with air. Hook it up to the ignition switch. Set the initial idle to about 500 & set it with the selenoid to 6-700. When you shut off the key the selenoid will let the throttle almost close. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#61281 06/03/2006 9:38 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | I'm sure someone much more knowledgeable than me will come along shortly, but can I ask a couple of questions?. What type gas are You using,(octane), and could it be possible You have some carbon buildup?. Maybe time for a little Marvel Mystery Oil.
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | |
#61282 06/03/2006 11:37 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You have something causing a hot spot. The timing makes no difference since the plugs aren't firing with the ignition off. acwhite is on the right track by suspecting a carbon build up. Setting you idle down can help sometimes but to FIX it you need to eliminate the hot spot that's acting like a spark plug when you turn the key off.
#61283 06/04/2006 7:45 AM | Joined: Apr 2006 Posts: 53 Member | | Member Joined: Apr 2006 Posts: 53 | Engine just rebuilt. has about 600 miles on it. I use 87 Chevron or Shell. I lowered the idle speed down a tad and it seemed to cure the problem but,....it still deisels every so often maybe once a week. Its a daily driver. I checked for vacum leaks there was a little one at the base of the carb so I fixed that. I like the idea of adding an idle solenoid so I'll be looking for one. I run AC RT44 plugs. Maybe too hot? | | |
#61284 06/04/2006 3:02 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | No those plugs are not too hot. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#61285 06/04/2006 6:35 PM | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | How do you use the Marvel Mystery Oil? Do you just dump a bit in each of the cylinders and put the plugs back in and let it sit for a few hours? Drew | | |
#61286 06/04/2006 7:05 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Some people get out in the country where the smoke wont get out the fire department, and pour some down the carb while its running. It will smoke likes its on fire, so make sure Your not in downtown Burbank. :p
#61287 06/04/2006 7:47 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have used Seafoam to clear carbon-take a well warmed up engine, put a can of Seafoam down the carb or thru a vacuum line, adding the last little bit quick enough to stall engine. Let sit 15-20 mins, then restart & rev engine, I like to drive them. they will smoke like Hades for a while, but it will stop. his is nearly identical to the "top end cleaning" done by GM dealers. brian | | |
#61288 06/04/2006 9:28 PM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I like seafoam to. Used it on quite a few of the ol trucks. Seems to work well to. Just make sure you arent downwind when you fire her back up!
Jeff | | |
#61289 06/04/2006 10:28 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you just have a few miles on a rebuild I doubt you have a carbon hot spot. Sometimes a nick or burr in the piston or cylinder head can become hot enough to ignite the fuel, causing dieseling. Like a glow plug in a diesel. Unfortunalely the only way to check that is to pull the head unless you have access to a bore-a-scope.
#61290 06/04/2006 10:32 PM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | I'm inclined to agree with Wrenchbender Ret. Your throttle blades are simply too far open at idle. Recheck the dwell just to make sure it's OK. Set the timing up a couple of degrees as Wrenchbender said. That should increase the rpm a little. Reset the idle speed screw to bring it back down, then reset the idle mixture. Good chance you'll have to reset the idle speed down again.
An idle solenoid is for a smog equipement burdened '70s engine or a small 4-cyl with not enough power to handle a AC pump at idle.
'67 GMC 3/4 292 4spd
#61291 06/04/2006 11:44 PM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | While it is true that a hot spot can ignite fuel air mix and contribute to deiseling, if there were no fuel air mix it wouldn't matter. Long way of saying, get the idle speed down and the problem will be fixed. Even a normal engine can do this after a hard workout on a hot day IF the idle is too high. Run on was a big problem in the early days of smog equipment because of higher temps and high idle to run A/C without overload or overheat. The idle soleoics mentioned were and are the solution, if just dropping the idle to 550 or so doesn't do it. | | |
#61292 06/05/2006 12:21 AM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Ok Ill bite,
Technically speaking when no power is to the plugs, as in ignition off, what ignites the fuel mixture if not a hot spot? No power means no spark. No spark means no igniting the fuel. Hence no dieseling. I would think 600 miles is way to soon on a rebuild for it to have carbon spots. Why does the idle speed affect this?
Please enlighten me. Jeff | | |
#61293 06/05/2006 12:47 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rustednuts, as the guys have said if the idle speed is down and hence throttle plate is closer to being closed little or no oxygen exists for combustion to take place no matter what the ignition source is, hope that helps. | | |
#61294 06/05/2006 1:47 AM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | Ignition with the ignition off is caused by latent heat of the head/block plus the heat of compression,(think how hot your air compressor head gets).. That's why it happens on engines that have been run hard, like towing on a hot day. The head temp is probably around 250 and coolant is 240 or so. Slowing the idle reduces the amount of air/fuel and reduces the heat of compression. If you have ever worked with diesels you know how hard they are to start with low batteries, same principal, slow revs lower heat of compression. | | |
#61295 06/05/2006 2:03 AM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | running on caused by,,,,idle speed to high,,late timing,,,carbon buildup in cyl...doc | | |
#61296 06/06/2006 4:29 AM | Joined: Apr 2006 Posts: 53 Member | | Member Joined: Apr 2006 Posts: 53 | Great news! first I want to say thanks to all for your help and input. I was under the hood today and bumped the timing up to 6 degrees BTDC kicked the idle speed down to 600 RPM and now I'm good to go. No more run on and it idles so smooth and quiet you can barely here it run while sitting in the cab. I guess the 292 likes the advance. | | |
