1 members (J Lucas), 98 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
#611962 01/21/2010 3:50 AM
I need the location of the cab mounts for a 52-3100 on a 82 S-10 stander cab long bed.I am doing all the fabrication out in the driveway under a tree.
CFG61 #612026 01/21/2010 12:14 PM
Chester, I have not done this myself but I do know there are aftermarket dealers of the mounts you need. Perhaps their sites list the dimensions you are asking about. Good luck with your sahdetree project.
Here is a link for what you are trying to do.
http://www.chevytrucks.org/tech/s10_frame_swap.htm
Drew
I'm not aware of any measured drawings you can just buy to do this. I think most the DIY crowd fits and cuts and they go. At least that would be consistent with the pictures I've seen.
The best looking NON-kit installs have been where someone built some nice looking mounts and then bolted or welded those to the frame after attaching them to the body and getting it exactly where they wanted it.
I think you are right. When I think about it that is the way I will go. I will sight it in! Thanks for all the help. dang
CFG61 #612313 01/22/2010 11:53 AM
I originally considered a jig, then I did exactly like Steve mentioned. Build the mounts, located the cab, tack the mounts, remove the cab, weld the mounts - done.
I added isolation mounts to mine as well to make up for any missalignment and pull during welding.
http://good-times.webshots.com/photo/2270648590101989507YWlMmu
http://good-times.webshots.com/photo/2115114610101989507uXcegV
Very nice pic's. I can see clearer now. Thanks Scott.
since your doing your kit yourself, 5" off the frame for the front mounts and you dont have to modify the cab floor. 3.5" like I have and you have to build a trans tunnel. between 1.5" and 3.5" and you are building a trans tunnel and driveshaft tunnel.
Below 1.5" and you are into new sheetmetal for the back of the cab. The following pic is with 1.5" of spacer between the frame and cab (a piece of 2 x 4)
http://good-times.webshots.com/photo/2917645630101989507lTpKbX
here is a link to my swap that has other useful links https://www.stovebolt.com/ubbthread...;Main=58105&Number=421710#Post421710
