1 members (Dusty53),
174
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61243 06/03/2006 5:21 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Having problems with vapor lock. I have never had this problem before my last fill up. I have heard of winter gas being more prone to vapor lock than summer gas. Is this true? I got a fuel discount and opted for premium on my last fill up. I usually run regular. That is when the problems started. Could it be that I got a tank full of winter gas that has caused the problem? I am pretty sure it's vapor lock because I see the gas percolating in the filter. Also, almost no gas in the glass filter when problem exists. The fuel pump and carb are also very hot to the touch when problems arise. Water temp shows 180. I can pour cool water on the fuel pump and usually get back home. Motor is a 235 with carter YF carb. Thanks, Bob | | |
#61244 06/03/2006 11:28 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I had vapor lock issues. Electric pump with a full return system fixed it once and for all. http://www.chuckthetruck.com/Page26.html at the bottom. | | |
#61245 06/03/2006 2:32 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Hey Chuck, thanks for the good advice. Great site! Do you have to dump the return into the tank, or can you just put a "T" inline aft of the pump? Thanks, Bob | | |
#61246 06/03/2006 11:40 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Vapor lock is caused by a weak fuel pump. An electric or new mechanical pump should fix the problem.
#61247 06/03/2006 11:47 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I put a new mechanical pump on it about a month ago. Got it from NAPA. Seemed to work great up until the last fill up. Cam lobe worn? If I go with an electric pump, what psi will work best? I saw 2.5 - 4 psi and 3.5 - 5 psi pumps @ the local FLAPS. Thanks, Bob | | |
#61248 06/04/2006 12:07 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Your theory with the winter gas is probably the problem. It is much more volatile. You might insulate the gas line from the pump to the carb. If you use the electric pump don,t go over 4 lbs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#61249 06/04/2006 12:23 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | put some wooden clothes pins on the line tween the pump and carb til you use that gas up [old flathead Ford trick in Aridzona] - also put a 160 thermostat in, 235's run better cooler
Bill | | |
#61250 06/04/2006 2:55 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The clothes pin trick worked for me as a temporary fix on an old 57 F@&d I used to have as a kid. (smiling inside as old memories were brought back)
#61251 06/04/2006 2:47 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Bob, I ran it back into the tank so the "hot" fuel could co-mingle with the "cold" fuel in the tank before going around again. There was room in the sender flange for a 3/8" tube. Drilled a hole undersize, extruded it with a punch and socket, ran the tube through, clamped the tube to the sender bracket, then soldered it and epoxied it. No leaks, no problems. | | |
#61252 06/04/2006 3:25 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Thanks all. I have insulated the fuel lines and tried the clothes pin trick with no luck. I think I may go the electric pump rout. This is my daily driver, so it needs to be reliable. Thanks again. Bob | | |
#61253 06/06/2006 4:28 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Bob - you need to find out what's wrong and fix that instead of changing things - there's NO reason that a normal 235 would run that hot no matter the gas - do you have the correct [thick] insulator under the carb? and consider changing to a 160 thermostat!
Bill | | |
#61254 06/06/2006 5:04 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Hi Bill, I have both the 160 themostat and the phenolic insulator under the carb. Would the engine run hot if the valves are too tight? I adjusted the valves a few weeks ago and they are tighter now. I set em at .008 Intake and .017 on Exhaust. Water temp doesn't get above 185 on the gauge. Hard to get it to idle well now. I just got some fresh gas in her today so we will see if that makes a difference. I went to a different station and the new gas does not have any ethenol in it. Engine seems to be getting too warm but the water temp looks ok. ??? | | |
#61255 06/06/2006 7:25 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Try advancing the timing. Premium fuel burns more slowly than regular and is less efficient in a low compression engine and can cause overheating because the the fuel is still burning at the end of the power stroke, giving the same indications as retarded timing. You are not doing your engine any favors by using any higher octane than is needed to prevent pinging. Stories of low compression engines running better on premium fuel are just BS, not physically possible. | | |
#61256 06/06/2006 7:46 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Shipwright I'm guessing You solved Your problems when You gassed up at another station. I also don't see a need for anything over 87 octane in these old trucks.
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | |
