4 members (papas52, Otto Skorzeny, Lightholder's Dad, Millenimech), 167 guests, and 0 robots.
Topics128,109
Posts1,056,266
Members48,439
#612140 01/21/2010 9:20 PM
How hard and how much time will take to remove the upper and lower section of a 41-46 Front Grill? The chrome is flaking and I want to have it blasted and painted.
Well lets see, you have to take the hood of first. Then the baffel plate between the radiator and the grill. The upper and lower grills are bolted together. You can take them off both together or separately. I would try to remove them together. There's a bunch of bolts and screws aroung the perimiter of the grill(s) that attach it to the fenders and the lower valance between the bumper mounts
It's not too hard to do, just kind of a pain in the butt. It will thke several hours to a day depending on how bad the screws/bolts are rusted.
Good luck
George
I just took mine out and it wasn't to bad, I was lucky, most of the bolts broke, if you have the correct tools it shouldn't take more than a couple hours. Just be prepared to cut them off if they won't come off if stripped, a small die grinder worked good for me, I used a hacksaw also. I took mine in 2 pieces and it went fine. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Apprentice
Apprentice
I will need to do the same soon too.
