9 members (Wally / Montana, UtahYork, Frank50, BarryP, BC59, cmayna, DadsFirstPickup, Gray_Ghost, 1 invisible), 125 guests, and 2 robots.
Topics128,134
Posts1,056,740
Members48,454
#611999 01/21/2010 5:54 AM
1 Offline
just got this truck a month ago, and have been tryingto get the fuel gauge going. replaced the dash unit. reads full constantly. realize there was no ground wire coming from the sender so i clipped a heavy speaker wire and made a ground, still reading full. looked at the chevy manual and checked the wiring diagram and now i think i may be missing some stuff. currently i got a brown wire running from the sender to the ignition spot on the fuse box. in the diagram it goes through a gas gauge connector, then into an instrument cluster connector then to the ignition switch. maybe i'm posting this prematurely, but ithought maybe someone might have some insight that would save me some minutes.. any thoughts?
on my 65, im pretty sure the wire from the sender plugs into a spot on the fuse panel. not sure if its the same on a 62
Have you checked the sender? Lots of previous threads (as I recall) have a good discussion on the method to test sender, float, ground, and resistance. My wiring also goes to fuse panel. In my case my gauge is currently indicating from full to half. Half is where I run out of gas. Keeps things interesting.
HB
~ HB
1962 Chevrolet C10
1962 Suburban
mine is the same way. half=empty
1 Offline
found some pics of a 65 fusebox, my sender wire is going to the same spot. so today i guess i'll check the float to make sure it's moving and make sure the ground is sound. or i guess i can just get gas regularly and call it good!
I recently had that happen to my 1966 C-10. The copper strap in the sending unit was broken. I was able to fix mine by soldering in a piece of 12 gauge copper wire. thumbs_up
also make sure you have a good ground from tank sending unit to the body
Apprentice
Apprentice
The fuel gauge of this vintage, pre '65 works on 0-30 ohms.
0-1 ohms = E
15 ohms = 1/2
30 ohms = F
The brown wire at the fuse block is for the fuel gauge. From the fuse block the wire leads to the fuel tank sender.
From the fuse block male spade terminal the circuit leads to an in-line connector above the steering column then to the gauge.
Disconnect the brown wire at the fuse block and check resistance of the sender through the wire to ground.
At the terminal of the fuse block, wire disconnected, you can test the gauge operation.
With the terminal grounded and key on, gauge should go to E.
With 15 ohms of added resistance from this terminal to ground, should have 1/2 tank.
With 30 ohms of added resistance from this terminal to ground, gauge should go to F.
