| | | Forums66 Topics128,139 Posts1,056,455 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 19 New Guy | | New Guy Joined: Oct 2009 Posts: 19 | I would like to replace the door rubber and the rear window rubber on my '61. The rear window is broken and the doors are missing the door side rubber. I notice quite a difference in price between LMC and Steel Rubber so are their products twice as good? Thanks for any suggestions! | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I cannot vouch for steal rubber, but did use LMC. Replaced rear window, windshield and all door rubber. Door rubber was the only rubber I wished I had done more research with prior to buying. Local glass guy made some recommendations and had opinion on the door rubber specific to quality, fit and installation method (glue). I was able to use some rubber he had that was more robust, fit better and had a metal pinch piece that eliminated the need to glue. I believe I will also be able to remove the door rubber if I need to (for paint) and reinstall. The glue-in method required for the LMC rubber would not allow that. Windshield and rear window rubber - no problem. HB | | | | | Joined: Oct 2009 Posts: 19 New Guy | | New Guy Joined: Oct 2009 Posts: 19 | Thanks, I'll check and see what method SR uses for attaching. I am quite a way from painting but it would be nice to not to have to buy it twice. Appreciate the feedback! | | |
