2 members (Erniegp, J Lucas),
89
Mod | | | Forums66 Topics128,054 Posts1,055,781 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#6121 11/25/2002 12:15 AM | Joined: Mar 2000 Posts: 18 Member | | Member Joined: Mar 2000 Posts: 18 | Could someone tell me why my carb on my 40 Chevy pickup will only run when the choke is half closed? I had the carb rebuilt and I was having problems with the in line fuel filter only filling up half way which I had posted earlier. At the same time I replaced the fuel pump, the short piece of gas from the tank, cleaned out the fuel lines, replaced the dist. cap, points , condenser, plug and plug wires and reset the timing. Only after playing around with the choke, I found that it will purr like a kitten with the choke half closed and the fuel filter is now staying full. What gives? By the way, the heat riser is working.
thanks, Ken | | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Sounds like it's time to rebuild the carburetor. I think you have some particles plugging some passages in the carburetor and the float level is too low. Have you tried turning out the mixture screw to richen up the mixture? Sounds like your running really lean.
Joe
| | | | | Joined: Mar 2000 Posts: 18 Member | | Member Joined: Mar 2000 Posts: 18 | Joe...the carb was just rebuilt and I have tried adjusting the air mixture. Maybe my problem is it wasn't rebuilt the right way. thanks, I'll try tinkering with it a little more.
Ken | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Is it a Carter or a Rochester? | | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | If the carb has just been rebuilt, give the rebuilder the benefit of the doubt (no, we didn't do it), that something else may be wrong.
If the engine runs nicely with half choke, then obviously you have a lean condition. That condition could be something in the carburetor, but it could also be a vacuum issue (vacuum leak at a gasket, vacuum advance, etc.). Before re-rebuilding the carb, would at least look at the vacuum.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#6126 11/25/2002 11:11 PM | Joined: Mar 2000 Posts: 18 Member | | Member Joined: Mar 2000 Posts: 18 | Ken....It's a Rochester Jon...thanks, I'll check for any vacuum leaks.
thanks, Ken | | |
