| | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | I finally got around to reassembling the hood on my '50 1/2 ton. I checked the factory assembly manual and see that there is a brace rod that goes from latch panel to the hood sheetmetal on each side of the hood. My pre-disassembly pics confirm that these were missing from my hood. Does anyone offer these as a reproduction? As an alternative, what is the center to center distance of the holes in the braces so I can "roll my own"? Thanks
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | On my '49 1/2-ton, the center to center dimension between holes is 7-5/8". However, the holes are at right angles to each other and the rod has an angle at one end. It might be a challenge to fabricate. I don't believe the part is available from vendors. Suggest you try posting a want add in the swap meet. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Scott, give this guy a holler, he may be able to help. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 46 | I have them I think I have a old hood i can take them from can you link me to a pic so i can see what it is For sure.
Jaime
