5 members (TexasJim50, Peggy M, TexasA&M48Truck, Bill Hanlon, 52Carl), 90 guests, and 2 robots.
Topics128,094
Posts1,056,058
Members48,433
#611978 01/21/2010 4:36 AM
I finally got around to reassembling the hood on my '50 1/2 ton. I checked the factory assembly manual and see that there is a brace rod that goes from latch panel to the hood sheetmetal on each side of the hood. My pre-disassembly pics confirm that these were missing from my hood. Does anyone offer these as a reproduction? As an alternative, what is the center to center distance of the holes in the braces so I can "roll my own"? Thanks
1947, 1950, & 1952 Chevrolet 1/2 ton
1952 GMC 450 series Cab Over Engine
1946 Chevrolet 2 Ton
On my '49 1/2-ton, the center to center dimension between holes is 7-5/8". However, the holes are at right angles to each other and the rod has an angle at one end. It might be a challenge to fabricate. I don't believe the part is available from vendors. Suggest you try posting a want add in the swap meet.
Scott, give this guy a holler, he may be able to help.
More pix on Flickr.
I have them I think I have a old hood i can take them from can you link me to a pic so i can see what it is For sure.
Jaime
