1 members (JakeM),
129
Mod | | | Forums66 Topics128,275 Posts1,058,571 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 31 New Guy | | New Guy Joined: May 2007 Posts: 31 | My 1973 1 1/2 ton dump bed looses all the fluid in the master cylinder, it happens every couple of months and I cant find it leaking. I will say the master cylinder is rusty on the outside, but no signs of leaking and the brakes work great. I have looked at each wheel and in the cab as well as under the hood. The truck sits most of the time. I think it is either evaporating or leaking threw the walls on the master cylinder. One more thing where can I find a new master cylinder? It is a single bowl reservoir cylinder.
1955 chevy 1/2 ton long bed, and short bed 1967 Camaro RS work in progress 1968 Camaro work in progress 1968 GMC short bed work in progress 1968 Chevy truck work in progress 1972 Chevy Big block truck long bed 2001 Zo6 Corvette on the juice 2008 Chevy duramax 2500 hd 4x4 2010 Camaro 2SSRS
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | break the vac line on the brake booster. if fluid come out then you know where its going and it needs repair. | | | | | Joined: May 2007 Posts: 31 New Guy | | New Guy Joined: May 2007 Posts: 31 |
| | | | | Joined: Jan 2008 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 69 | It's very unlikely for a truck that size to have manual brakes. The booster is not on the firewall, it should be under the cab behind the left running board step. Like 51 ashton said, that's likely where your fluid is going. They don't like staying parked alot, the piston gets corroded and they leak internally.
TruckNut
Be kind, courteous, cheerful and helpful - And someone will take advantage of you.
"Quiting smoking is easy, I've done it hundreds of times." Mark Twain
| | | | | Joined: May 2010 Posts: 3 New Guy | | New Guy Joined: May 2010 Posts: 3 | I have the same issue on my 46. Will I need to replace the booster or can they be repaired? Best place to get parts?
Thanks!
The Bee Guy | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | does it spew pretty cloud of blue smoke when you pump the brakes while its running? if so thats brake fluid being burnt. you can find part and a new unit here http://www.abspowerbrake.com/index.htmli bought repair kits from them. not long ago i was quoted 250. for a new unit. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | Before you start spending money try this. Fill it up and go out about every 4or 5 days and pump the brakes a time or two. If this stops the leaking it is seeping past the cups in the cyls. If this is the case do not hone and rebuild,replace with new cyls. | | | | | Joined: Apr 2010 Posts: 26 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 26 | just had my hydrovac rebuilt ('58 c-60 viking 2 ton) by Ron at Karps Power Brakes in Ca. He was highly recommended by another bolter and I see why. The guy's prompt, honest, reasonable, and does excellent work. I also recently sent him my master cylinder to be re-sleeved with stainless. for the same truck. www.resleeve.com ask for Ron Wooley | | |
