10 members (cmayna, Woogeroo, Hotrod Lincoln, Njm, SmalltownTRKGuy, baldeagle, Ponchogl, walter74, 2 invisible),
344
Mod | | | Forums66 Topics128,165 Posts1,057,089 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Hi There,
I am new to truck tinkering and am the proud owner of a 1954 Chevy 3100 truck. The engine in the truck was shot, so I purchased a good motor from a 1955 Chevy car.
I am looking for advice on the best way to mount the car engine to my truck. The truck engine mounts are on the front, but the car engine mounts are on the side. Is it better to use the current engine mounts and fit them to my truck or drill through the motor and make the car engine fit the truck mounts? Is there a better way?!
I appreciate the help.
Carlos | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | Hi. best chassis mount kits i have found are from "chassis engineering" they have them for both boxed and unboxed frames weld in or bolt in, far as the 57 having side mounts? umm might be wrong but i thought chevy did front mounts on their V8s up through the 60s you might wanna run the numbers on that engine just to be sure what you have
1937 1/2 ton
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Are you talking about a car six cylinder? If so the lip should be on the mount plate where the truck mount holes should be. Just drill some holes and make them square with a file. | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Thanks for the replies...the car engine is a '55, 235. I will check out the links about drilling some holes.
Cheers,
Carlos | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | You can also use the front plate from your bad engine unless you really don't want to tear either engine apart to make the transfer.
Drew
| | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | I had another buddy suggesting that too. Is there a lot involved with that? | | | | | Joined: Jan 2010 Posts: 90 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 90 | 58 car was first side mount engine up to 57 6cyl had center front mount car and truck. 55 to 57 had 2 front mounts set at an angle on V8's. Been awhile since I really messed with alot of this on a regular basis but pretty sure I'm remembering correctly.
Also if I remember correctly 55 was first year for angled bell housing mounts. Vs' 54 back straight mounts.
1955 GMC 150, 1980 Chevy C10, 2011 Sierra 3500 HD SLT Duramax Dually Crewcab, 1960 Chevy BelAir 2dr sedan, 1978 Pontiac Trans-Am
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1955-57 pass and truck mounted on the front side, not in the center front. 1958 pass mounted in the center side, trucks stayed front side through 59. 1954 was the first angle bellhousing mount in trucks.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Ruckin Chevy, If I remember correctly from my 54 Chevy 3100, you have to remove the harmonic balancer, remove/lower the oilpan to access the two lower bolts for the timing cover, remove the timing cover, remove the camshaft thrust bearing (2 bolts), remove both timing gears (one on the crankshaft and one on the camshaft, and then you can remove the plate. It's your choice, but if you don't want to tear into the engine that much, drilling the two holes and making them square would do it, as Cletis said. Samantha | | |
