9 members (Gdads51, TUTS 59, Mike Burns, Mike'sPlace, Wickedbass, moparguy, SWEET, walter74, 1 invisible),
98
Mod | | | Forums66 Topics128,065 Posts1,055,870 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 18 Apprentice | | Apprentice Joined: Jan 2010 Posts: 18 | Hey guys new to this body style and model.I've got a 63 Chev.1/2 ton panel and need to know what will fit,like windshield,doors from what other years.Been able to look on this site for bout a week and got registered and was amazed how helpful everyone is.Thanks | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | welcome! Here's a what I believe is a list of years that exchange with each other. I hope others will add to the list. This should cover all 1/2 ton to 1 ton trucks/panels/suburban.
1960/63 * windshield - all
1960/63 * doors - all
1960/66 fenders - all
1960/66 seats - panel only
1960/66 door handles - all
1960/62 front bumper - all
1963/66 front bumper - all
1960/66 rear bumper -?
1960/62 rear bumper - suburban only
1963/66 rear bumper - suburban only
| | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | You are mistaken about the bumpers. '60-'62 bumpers are different than '63-up bumpers. Suburban rear bumpers are Suburban only, divided '60-'62 and '63-'66
Front suspension is '60-'62, '63-'66. Rear suspensions are likewise divided.
Radiators are also '60-'62, '63-'66, along with core support and fan shrouds.
The panel that the grille mounts in is different as well, '60-'61, '62, and then I think '63-'66, but it's just a matter of a couple holes. I put a '60 grille in my '62, and don't remember if I had to drill extra holes or if it was a bolt-in.
Kick panel vents are also '60-'61, '62-'66. -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Thanks Brad, I was guessing at best. I made the corrections. Since we are on the subject, what about the rear bumpers on the panels and the trucks? What about gauges, dash, emblems etc? | | | | | Joined: Jan 2010 Posts: 18 Apprentice | | Apprentice Joined: Jan 2010 Posts: 18 | Thanks guys you all are a lot of help,I have fooled with just about every model of Chev. but this is a first and needing to know what to look for.Thanks again, may need some more help. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I believe the '60 had a small script "Chevrolet" emblem on the glove box.
Instrument clusters are kinda all over the board, '60-'62. Some had full gauges, some had either a temp gauge or I think an oil pressure gauge, by '62 they were idiot lights and a gas gauge. The bigger trucks had full instrumentation, and that's what I found for my '62.
Not sure about any differences between panels and Suburbans, but definitely Suburban rear bumpers won't work on a pick-up--Subs don't have a recess for the license plate like a pick-up.
Oddly, the cable-operated kick panel vents have different mounting screw locations from the later lever-handled vents. The kick panel opening on the '60-'61 trucks also have a notch in the mounting area for the cable to pass through. I put 'em on my '62 and had to redrill the mounting holes on the truck, and cut the notch with a die grinder.
