7 members (55shaker, Nick in Manitou, Leo, 54farmtruck, Hotrod Lincoln, Bill Hanlon, 1 invisible),
108
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61156 05/31/2006 7:43 AM | Joined: Apr 2005 Posts: 1 Junior Member | | Junior Member Joined: Apr 2005 Posts: 1 | Are there any companies that will split the exhaust manifold for a 250? If not, has anyone seen instructions on how to do the job? I searched the forum and only saw mention that Kansas Kustoms would no longer do them because of high failure rate. | | |
#61157 05/31/2006 9:15 AM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | Instead of a split manifold, I went with headers. The set I got (Hedman) are split front-to-rear by design.
The stock exhaust manifold and headpipe is so restrictive that it seems to me that the only benefit from splitting the manifold is to allow a true dual exhaust to be fitted and change the exhaust sound somewhat. I know this is an old rodder's trick, but I don't believe it to be very effective for adding power. Some, yeah...but not nearly what you'd get with headers.
This is just my own opinion and based on my own experience...others may not agree. | | |
#61158 06/01/2006 7:06 AM | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | I had an original manifold that had been split probably years ago. It was cracking where the "new" elbow was added, so I took it to a good welding shop, and they pointed out to me that the spilt was never completed by putting a little divider into the manifold to separate the flow 3 and 3 (all the cylinders just dumped into one big space that had two outlets). They beefed up the welding around the add-on elbow, and put in a little piece of metal to split the flow evenly. Bottom line is: find a good welding shop with an old-timer (or younger guy, but usually it's an old-timer) who knows how to weld cast iron. It's an art, from what I understand. Can't say it added a lot of power (or any at all), but it sure sounds good. | | |
#61159 06/01/2006 11:21 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
