1 members (PAUL Berardi),
147
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I have a 54 3100 Stepside with a transplanted 283 attached to the original (to the truck) 4 speed transmission. I want to upgrade to a highway friendly rearend. I have a '69 Camaro 10 bolt posi with 2.73 gears for the replacement. Since the current bellhousing is bolted to the stock rear motor mount locations, I figure the motor is sitting in the correct spot and at the correct height. So I figured if I used a 55 - 62 truck 4 speed transmission it is exactly like mine (including the reverse shift location). The ditch I feel I fell into is dealing with a 2 piece driveshaft. With my planned setup, is there any other drvieshaft possibilities /configurations other than using the two piece driveshaft and only adapting the rear portion to the Camaro rearend?
Sorry for the book....but Thanks | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Custom build a single piece drive shaft. It would be a little on the long side but probably okay. Choose a local shop to do it for you, and I would not expect it to cost more than a couple hundred.
My '55 1st has a single piece drive shaft that seems to work just fine.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Check your local phone book, most cities have a shop that specialize in drive shafts, axles and housings. I've had 3 drive shafts built and while theyre at it installed the correct u-joints & balance. The shop can advise you on how long to make the shaft. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | A gas engine driveshaft can be used in length to 58" ctr/ctr of the joint if the tube diameter is large enough. A 3.25" tube should be fine but nothing smaller for that length. I've built 65" tube lengths where I had 4" diameter to work with but that is rare with 1280-1310 series. 1350 series will allow more flexibility.
| | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | Thanks for the information, but I can't seem to visualize How this will work. The rearend has a fixed pinion yoke and the rear of the transmission has a fixed yoke, so "where is the slip yoke"?
I suspect the 2 piece drive shaft has the "slip" at the carrier bearing area. Right?
Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | sounds like you have a closed drive trans [original], which is why you have a split shaft on a 1/2 T, the slip yoke goes in the back of an open drive trans [the later one], on the front of the front U-joint, pulls out [which lets the oil run out] ... you need to ditch the split shaft and get a one piece one for the open drive setup
Bill | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Thanks for the information, but I can't seem to visualize How this will work. The rearend has a fixed pinion yoke and the rear of the transmission has a fixed yoke, so "where is the slip yoke"? That's the parts you have today. Mine has the slip yoke on the transmission. Mine is a '55 1st that started with an open drive line but the parts are not hard to swap if you can find them.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You should find a lot of your driveshaft questions are answered here in the Spicer driveshaft manuals http://www.stovebolt.com/techtips/driveline/setup/index.htmlIf you're not using a factory driveshaft (can't understand what you're doing) then call a good driveline shop for both the expert advice and the new shaft. Grigg | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 54 3100
. . original (to the truck) 4 speed transmission . . - torque-tube rear-end and SM420 with u-joint cover?
. . if I used a 55 - 62 truck 4 speed transmission . . - open driveshaft with open u-joint (SM420)?
Both of the above have a u-joint yoke that is bolted to the transmission and the other u-joint yoke slides on the driveshaft spline.
. . The rear-end has a fixed pinion yoke and the rear of the transmission has a fixed yoke, so "where is the slip yoke"? . . - what transmission and rear end (drive shaft?) are you referring to? Maybe a few photos might be helpful.
All 1954 3100 Chevrolet trucks are "short bed" (and "step side", for that matter). Why would a two piece driveshaft be needed?
I know nothing about drive-shafts, but the people posting above are very knowledgeable. With more information about the transmission and rear end, you will get the best answers possible.
