4 members (baldeagle, 2-Ton, Gazz, KDrown), 98 guests, and 3 robots.
Topics128,097
Posts1,056,495
Members48,444
I want to swap over to a '60-'61 hood. Does anyone know if the hood latch is specific to that hood, or will the '62-up latch work?
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
The striker plate on the grille support is the same, but you'll need the latch in the hood for the 60-61. The pull faces down under the gap in the center of the hood. The 62 & up hood latch handle points to the driver side for access through the hole in the hood.
Here's an eBay example of a 60-61 latch:
http://cgi.ebay.com/ebaymotors/CHEV...torsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
What Markeb said...your hood will problably have the hood latch still attached and it will engage the latch mechanism on the radiator support.
