8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,140 Posts1,056,770 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I want to swap over to a '60-'61 hood. Does anyone know if the hood latch is specific to that hood, or will the '62-up latch work? Thanks, -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | The striker plate on the grille support is the same, but you'll need the latch in the hood for the 60-61. The pull faces down under the gap in the center of the hood. The 62 & up hood latch handle points to the driver side for access through the hole in the hood. Here's an eBay example of a 60-61 latch: http://cgi.ebay.com/ebaymotors/CHEV...torsQ5fCarQ5fTruckQ5fPartsQ5fAccessories | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | What Markeb said...your hood will problably have the hood latch still attached and it will engage the latch mechanism on the radiator support. | | |
