3 members (Hotrod Lincoln, Wooley, dt235sd), 112 guests, and 1 robot.
Topics128,102
Posts1,056,532
Members48,448
I have some skill with woodworking and I'd like to make my own bed wood. I know they take some careful routing and production. I just can't bring myself to pay someone to make them, then pay the shipping on something I can do myself. Can anyone help?
thanks
1962 short bed stepside apache.
(that needs new bed wood)
You don't necessarily need a router. All the cuts can be made on a table saw if you or a friend has one to use. Mar-K web site has dimensions and tech info as well as the Tech Links pages on this site. The important thing is to determine if you want a show or utility bed and picking the right thickness and quality of wood. If you have decided on a show bed you may actually find that Mar-K is priced about the same as buying your wood locally and of course ,most of the work is already done.
Drew
I did mine just as Drew describes. A neighbor who is a carpenter lent a hand. We tested on a few scrap pieces and less than 30 minutes later I was back home prepping for paint. The holes for the mounts were also very simple to do.
I plan on doing this also. I want to use "rough sawn" oak, and seal the crap out of it. If I have to do it again in 30-40 years, well, so be it!
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
