| | | Forums66 Topics128,101 Posts1,056,523 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 94 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 94 | I have some skill with woodworking and I'd like to make my own bed wood. I know they take some careful routing and production. I just can't bring myself to pay someone to make them, then pay the shipping on something I can do myself. Can anyone help? thanks Kevin 1962 short bed stepside apache. (that needs new bed wood) | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | You don't necessarily need a router. All the cuts can be made on a table saw if you or a friend has one to use. Mar-K web site has dimensions and tech info as well as the Tech Links pages on this site. The important thing is to determine if you want a show or utility bed and picking the right thickness and quality of wood. If you have decided on a show bed you may actually find that Mar-K is priced about the same as buying your wood locally and of course ,most of the work is already done.
Drew
| | | | | Joined: Mar 2009 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 45 | I did mine just as Drew describes. A neighbor who is a carpenter lent a hand. We tested on a few scrap pieces and less than 30 minutes later I was back home prepping for paint. The holes for the mounts were also very simple to do. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I plan on doing this also. I want to use "rough sawn" oak, and seal the crap out of it. If I have to do it again in 30-40 years, well, so be it!
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
